- Joined
- 31 Dec 2003
- Messages
- 173
- Reaction score
- 1
- Country
I have an external tap on the back wall of my house and I want to T off it to take a supply to another location. There is a recently installed expensive path underneath the tap which I am reluctant to lift.
I propose to use a core drill to drill on oversized hole immediately below the tap and excavate a hole in the lawn such that I could then poke a hole beneath the path and meet up with the hole near the tap. I would then feed the flexible section of water pipe under the slabs and pull it up to join the tap joint.
Is there a type of flexible pipe I could use to connect the tap to the conventional plastic pipe I shall lay underground? I've seen a type of corrugated pipe that looks like it may do the trick but could I then join it to the conventional rigid pipe?
Any ideas appreciated.
