Central Heating (gas). I have taken the old lathes and plaster ceiling down in my cellar. (Victorian terraced house). The existing copper tubes are below the ceiling level. I want to raise up all the tubes into the beams and then plasterboard.
Is it OK to use Flexible Hoses to make some new connections to the existing copper tubes 15mm, 22mm and 28mm. This will make is easier when re-joining.
Is it OK to saw notches out of the beams for the tubes? (Beam size 20cm x 5cm) they are 30cm apart.
Many thanks
Many thanks
