Flexible hosing
23 Sep 2009
Oxford
I recently moved my kitchen cabinet to replace it and found that there was a 1.5m flexible hose connected between the copper pipes. It is about 1 meter away from the boiler. I looked on the net and found that they have 13mm bore holes.
Should I replace these pipes with 22mm copper pipes as it might be restricting the flow of the water returning to the boiler?
It is not a filling loop (as i can see that on the boiler). It is not connected to any water supply. Just connecting the two 22mm copper pipes together.
Any chance of a piccie?
View media item 14792
thats arnold my frog over my shoulder btw ;)
Sounds like it has been done like that as a diy bypass.
I would get a plumber in to check what has been done and whether it is actually doing anything! :D
Haven't got a pic at the moment. The flexible hosing is metal braided. Basically there are two pipes one is flow and return. On the return pipe looks like someone has put a flexible hose (looks like diy job). I was thinking does it effect the flow rate to the boiler as the pipe is 13mm bore or does it not matter as the pipe is not that long?
