I seem to have a problem where water pools in the joint where the wc spigot enters the flexible connector. Theres a channel in the joint just before the concertina part and over time it starts to leak. On taking apart this channel is full of water dispute me being sure the pan spigot is passed this channel. The connector is from Wickes. The connector is also very difficult to push tight over the spigot.
I've got hold of a rigid straight extension piece which pushes tight on to the wc spigot, cut down and inserted the end into the flexible connector so that the joint in the flexible is bypassed. The flexible does a 60 degree sloping downwards into the internal stack. It seems to be ok at the moment, but will it cause problems in time? I.e. 2 pipe connectors attached to each other?
