need more info Bongo.
If its a concave curved step then a pvc nosing might be coaxed around it with some heat. Otherwise you have to make a template and send it to the manufacturer for an aluminium nosing. there are a few manufacturers of pvc and aluminium nosings and their products can be obtained from your local flooring contractor or distributor.
Thanks......aluminium nosing would be ideal as it would match the others in the room (it is a concave curve) I'll try a local flooring stockist....thanks again
