Want to use flexible tap connectors (maybe John Guest). Note that these can cope with up to a water temp of around 65 degs C. With the combi boiler I have, if the CH is running, the water from a hot tap may initially run much hotter than the temp set for hot water on the boiler (Worcester Bosch) and the temp limit of the flexible connector might be exceeded for a short time. Is this likely to be an issue leading to leaks or failure on the tap connectors?
