I'm replacing the old taps on my bathroom sink, I'm going to install flexible tap connectors 13mm inside diameter and isolation valves while I'm at it, as the flexible tap connectors have a rubber washer I assume no fibre washer is required, a little smear of LS-X and just a nip up is required, as in quarter turn from hand tight as not to deform the rubber washer, sorry for such noob questions, but moneys tight and I've got a lot of work to do.
