flexis
JPC
10 Aug 2004
Leicester
hi...any ideas who might supply flexi tap connectors that are about half the size of the usual 300mm length..i'm talking about 150mm length ..tap connector one end 15mm compression other end..or dbl 15 mm compression ended
any ideas..?
Why not use push fit tap conns and pipe couplings and plastic pipe, cut to whatever length you want then. :)
I often find the standard 300mm ish flexies to be an inconvenient length. So I use longer ones, with a loop in. Makes life much easier and strains the flexies far less. They#re readily available at 450 600, 900...
People often don't realise you can screw the "tap" end of one standard flexy on to the "pipe" end of another to make any length you want, by the way.
And if you have a tap with pipe connections poking down, reverse the standard flexy. That gives you a 1/2" female swivelly end, which you can screw straight onto a compression isolator after you take its nut off.
