Flickering Down Lighters
21 Nov 2007
Yorkshire
I have recently installed 6 12v Down Lighters with 20w Filaments using individual 230/12v transformers. All 6 operate from one 2 Way Dimmer Switch rated at Min.Load 60W/VA Max.Load 400W/VA, the second way providing on/off facility at another door. At different light level settings all 6 lights flicker sometimes, although a setting can be found where the flickering will stop. Can anyone tell me a reason for this. Thankyou.
Are the transformers suitable for dimming?
Is the dimmer suitable for dimming lighting transformers?
Is the dimmer new?
How much did it cost?
Is the dimmer new?
I asked for dimming transformers and compatible dimmer and yes the dimmer is new costing just short of £10.00
Is the dimmer new?
something is wonky with the above.have you checked the trannys to see if there is a 'dimmable' sticker on them and is the dimmer the right one.
its not uncommon for wholesalers to give out the wrong stuff by mistake
