Hi there,
I can no longer use my living room lights as each time I turn them on they flicker. No other lights on the same loop have this problem; just the ceiling light in the living room.
I replace the light fixture, which didn't do the trick. I checked the wiring at each switch (2-way dimmer switches) and everything thing seems to be ok.
I'm totally stumped as to what is wrong as the lights just all of a sudden started to flicker - i've not done any work to the house.
I'll will probably have an electrician come over to inspect - but I would very grateful for any advice / suggestions from this forum.
Thanks in advance!
Thanks in advance!
