Flies in the loft
6 Apr 2005
I went into the loft at the weekend to check out whether I could find where my roof is leaking. When I opened the hatch lots of flies came out. I'm wondering whether there is a dead bird/animal in there or whether flies sometimes make a nest. Presumably they need something to feed on. Are there any other causes? Will they just die in the cold weather?
Flies will 'winter-over' in lofts and such places. Especially if you live near a farm yard.
joe
This ius quite normal, only worry if your loft smells rotten, perhaps santa got stuck last year. ;)
You can often see them on sunny walls at this time of year, getting a warm, they are the ones about the size of blue bottles, they may even be said fly.
Just dome some quick research, see the section on flies here http://www.oum.ox.ac.uk/bugquest/bugid2.htm#flies:cool:
The flies.. If notso lucky you may have 'cluster flies' Apparently not a huge problem.
Our local council has a page on them ..
http://www.bathnes.gov.uk/BathNES/environment/animalsandpests/Pests/ClusterFlies.htm
I am sure you will find plenty of info on the web... Your own local council perhaps ?
We have a South West facing gable end .. some flies sun themselves on it... in the cooler afternoons.
It has been said that darker paint may dissuade a few of them .. they like the reflected heat from light colours .. don't get much up those spindly legs I suppose.
Non in loft tho.
Contact the Lord of the Flies.....he`s out there on the Web :rolleyes:
I found some old zips in the loft, i think they were from mens trousers, i just threw them in the bin
some punk had been squatting there :eek: :rolleyes:
