Flipper or Bubble seal?
4 Dec 2007
Hi all,
The flipper seals on our upvc front door and 2 windows have perished and in need of replacement. I was just wondering whether to replace the current flipper seal with a bubble seal or something else which might be better then a flipper seal or is it best to stick with the same type?
Thanks!
Stick with what you've got and as close to the same size as poss, obviously you need to factor in how much the old stuff has flattened over the years, if you put to too thicker gasket in especially the door you'll need to start adjusting hinges and locking keeps as you'll have too much compression, windows a little bit easier to adjust
