Hello all,
Next part of house project due at the weekend - dining room needs a lot of plaster attention..... Can't wait!
Back of the chimney stack is in the corner and has cracked badly, so I suspect I'll need to take it all back to brick/block (at least here).
It has an external angle on the corner.
I would like to continue with the float & set, but have not had to handle an external corner before.
What's the recommended course of action with the external corner bead when floating and skimming later?
I can see there maybe two solutions -
a) get one of the thicker float beads and float level with this and then stick a thin coat bead over the top when skimming
b) just use the thicker float bead and remove a couple of mm depth to about 1ft away from the bead
Can see there would be pros and cons with each. Or of course maybe something else?
TIA
TIA
