hey I have a problem with the float valve that came with the new toilet I fitted its similar design to Fluidmaster 400 Bottom Entry Fill Valve Euro 3/8" on the screw fix site but a much cheaper version. Problem is the float bit that is meant to move up when the water rises doesnt move up as it has too much resistance against the straight bit. Has anyone had this problem before is it likely to be a faulty float valve?
