Floating engineered wood floor - membrane required?
27 Mar 2007
Surrey
Hi everybody,
I will be laying a floating, engineered wood flooring in my kitchen. I'm happy to use 5 mm fibre boards for the underlay but I suspect that a damp-proof membrane would be a good idea.
Half the kitchen floor is screed, with cellotex, on top of block & beam. The other half is 18 mm chipboard suspended on joists. The threshold between the 2 is completely level.
Is a DPM advisable, and if so, what would you advise? (Plastic sheeting, bitumen-backed building paper etc.)
Many thanks.
You only need a DPM if the floors damp. The chipboard certainly isn't, and as there's cellotex with screed on top of it, that shouldn't be either.
Thanks Doggit. I might give the membrane a miss then.
