I've recently installed a floating floor over a concrete slab in a garden workshop.
Due to height concerns (door threshold/plug sockets) I went for 25mm PIR under 18mm T&G OSB (with DPM and slip layers).
I've got a lot more floor deflection than expected, would 3.6mm plywood laid perpendicular to the OSB spread the load or do I need to consider raising the plugs and stuff to potentially go for something thicker?
Any knowledge appreciated
