floating oak flooring removal..?
20 Oct 2009
Cheshire
Hello!
Bout 20 months ago had an oak floor ( 15mm. by 1m) fitted by a joiner, didnt have a clue how to do it been told later.
I want to remove carefully as want to relaid ( its in very good conditioned itself, nothing wrong with it apart from the way it was laid).
It is tongue and groove, glued. laid on top of concrete floor.
Not nailed, just floating on top of concrete floor. the problem is the glue in the T & G joints.
Never done it before. How Do I deal with this ??
it will be glued together if its floating
if it is glued then recycling is extremly limited as you now have a large board that can't easily be seperated to a clean reusable planks with clean joints
big-all is right, many T&G's will damage beyond "repair". But if your concrete floor is level and sound then you can re-install your whole floor glueing it down with flexible adhesive.
It's worth saving an oak floor if it's in good dondition (i'd save it even if it was bad!!)
Wood flooring adhesive dries very brittle and comes off tongues or out of grooves easier than you think. Buy one chisel that just fits inside the groove about 5/6mm , keep it sharp, get some tinnies in and plod away. It's the only way, will take a bit of time but will save you money !! enough to buy some dpm underlay and fit it correctly.
Hello!
Agree with that, any Oak floor worth its due is worth salvaging
Don't agree with this. Tongue will snap/damage due to glue - proper glue should not get brittle otherwise any movement in a normal floor in normal circumstances would break the bond of the glue too and create gaps etc.
