Chaps
I am looking to fix a piece of 38x960x400mm Worktop to a wall as a work surface for a computer keyboard (monitor on the wall). The effect will be of a floating shelf. I need suggestions/links to an invisible bracket solution.
The wall that it will fix to is Dot/Dab on Cavity Brick wall. I am planning a backboard above the work surface so I can dig out the plasterboard if required.
I have seen a suggestion of threaded bar fixed in a drilled hole with resin and this looks pretty sturdy but I wonder if there is a solution that involves a right angled bracket that is rebated underneath the work surface.
Feel free to tell me it won't work!
Regards
Kevin Russell
Regards
Kevin Russell
