Flood Light Wiring
4 Jul 2010
London
Hello I got a floodlight with 3 connection
Live
neutral
Earth
But outside the house has four wires
Live (Red Wire)
neutral (Blue wire)
Earth (Lose Green/Yellow Wire)
Yellow Wire with red sleeve?
What is this yellow wire for and how do i connect this
I connected
L=L
E=E
N=N
Left the yellow wire lose
it worked but i think it went out, bulb busted, I have a switch that is connected to the light but that didnt work when the light was working
any ideas how i should wire these thanks in advance
Red = permanent live
Yellow with red sleeve = switched live.
Connect the yellow to the L terminal in the light, and put the red one in a separate terminal block.
thanks man ur the best the lights working now
will this allow the light to come on automatic without the switch being on or does it work the other way round were u leave the switch on and the light comes on/off automatic
You leave the switch on, and the sensor will switch it on/off as needed.
Some have an override feature where if you switch the light off/on quickly, the light will stay on permanently.
sicko said:
ur the best...u leave .... ur a star
I'm glad you got your problem sorted.
If you have any more issues you'd like help with please do us the courtesy of writing in proper English.
