Flooded trenches
18 Feb 2006
Birmingham
Hi all
Dug out footings a few weeks ago for a new retaining wall in the garden. Just before we were going to pour concrete it rained constantly and since it’s been full of 4” of water.
I’ve Pumped the water out and walking in trenches it’s soft, like walking in wet concrete. Any advice of what to do, wanted to get concrete poured. Ground is clay
thanks in advance for any info
I have only come across this incidentally, but the practice was (on the day concrete is to be poured)
pump it out
scrape out the soft mud from the bottom of the trench
pour a drylean mix into the trench and compact, to absorb remaining moisture and give a clean bottom
Pour the main mix.
pump it out
Pour the main mix.
Thats how I would deal with it if I was inspecting it.
it's the standard instruction on the plans for substations.
I followed it when replacing a leaking drain.
Hi all
is it worth putting rebar in the footings or prefab cages?
Not normally unless you are bridging over soft spots, capped of wells,changes in sub soils (ie changes from clay to sand) etc. I used to work in an area where there were abandoned mine workings and it was used very extensively.
It was all hard until Undisturbed clay until the rain we had and trenches sat in 4” of water
