Yes, there's a moral to my story, and its probably "leave this stuff to the experts".
Fitted a floodlight on the front wall of the house, intending to cut into the lighting circuit cable in the loft of our bungalow and fit a junction box to take the supply for the floodlight. Because there was insufficient slack to allow me to reconnect the old circuit cable in the junction box, I extended the cable using a connector box, then made the connections for the two ends of the circuit cable and the floodlight in the junction box. No power. So I disconnected the floodlight, remade all the connections, still nowt. Tried remaking all the connections several times, but without success.
Lacking testing equipment, I had identified the lighting cable by tracing it back from the nearest ceiling rose. There are two lighting cables from the rose; one disappears into the ceiling, so must go to the switch, the other is routed with other cables to the CU, and its the latter one that I cut into for the floodlight supply. All other circuits are working OK.
Anyone any idea what I've done wrong? Thanks in advance
