hi, does anyone know what size cable i should use for a security floodlight outside?.
i have a spur running off a junction box on the main ring curcuit and this goes into a switched fused connection unit.
but what size cable should i use going from the fused connection unit to the floodlight,should it be 1.00mm or 2.5mm? also what size fuse should i use for the connection unit 3 or 5 amp thanks
