Floor Advice
27 Dec 2008
Lancashire
I need some advice on how to tackle my kitchen floor, it's currently a mismatch of different materials and I just wanted to know how a "Pro" would approach it.
It's a "L" shape room with Asphalt in the corner, Concrete at the top (with what looks to be an old drain), and to the right a very poor concrete patch job and Concrete again. Basic diagram attached.
My problem is I've go no idea how to fix it, so any help would be greatly appreciated...
Thanks.
Depends what you mean by "fix it". If you just want to level it all up using a homogeneous material then, assuming the sub-floor is sound, you can use a self leveling compound.
Ardex K15 would be ideal for your situation as it is suitable for both concrete and asphalt.
hth
