Hello,
I have just built an extension on my bathroom. It is to house a large bath sunk into the floor.
I am constructing a WBP 22mm floor, around the edge of the bath. (approx 600mm all around the edge. The rest of the bathroom is old style floor planks/boards. Again 3/4". The whole are will be tiled, and the existing bathroom, 12sqm is larger than the new part, (only about 3sqm of tiles around the edge of the bath)
Electric UFH will be installed.
Option 1.
Sit ply level with current boards, use a backer board across the whole floor.
Option 2.
Sit ply level with tops of current boards and reboard the whole bathroom with marine ply. The problem is then the step to the landing area.
Option 3.
Something else. I.e. Take up existing floor and replace with ply.
I have also got to install an 1800mm x 1000mm shower tray. This is the flush type that should be bedded on ply/cement. I could either. Remove the boards underneath and replace with ply, or if doing the whole room Just go on the top.
Option 1.
Option 2.
Option 3.
