Floor Boards
I recently had a guy in to do this and he swore by taking the sawdust from the second sand (this layer was close to "proper" wood colour, unlike the first sanding), then mixing it with varnish and some pva glue. Then he filled the gaps using a filling knife (admittedly none were more than say 8mm - bigger ones than this he filled with spare "tongues" we found under the floor).
(PS my floor had originally been T+G, but years of clumsy plumbers and electricians has put paid to most of the Tongues)
Once it had all dried he did the third sand and it was pretty convincing!
Good luck :)
Must be standard prictice ;) , most have mine have been knackered also, looks like the spark used brute force to lift the boards, some have great big chunks missing, not just the tongues. I always thought you used a circular saw along the length of the join, that way you only ruin one board.
