Hi I am putting a gravity drain washing machine in a utility room. The 4 inch floor drain has no trap and appears to be just a bend. I would rather not dig up the floor to install a P Trap, so was wondering if there would there be any issue with smells or anything if I just fitted a blank end to the drain and then drilled a hole the same diameter as the washing machine hose and sealed it into the drain. The drain facilitates the washing machine and a sink and no toilets or anything.
Any advice greatly appreciated
