Hi
It seems that the plasterer didn't do as good a job as I'd thought.
After discussion about heights before the work starting it has ended up 15 mm too high and I need to try and claw back at least 10mm.This will take it to 2-3mm below the height of the wooden threshold.
To that end a couple of questions :
1. Can I screw the 10mm Marmox UFH insulation straight to the screed rather than lay it on a bed of adhesive ?
2. I had allowed 5mm of height for the encapsulation of the UFH in SLC, Is that about right ?
3. If I lay the 10mm thick porcelain tiles on a 10mm bed of adhesive how thick will the adhesive finish once bedded ?
4. I know it's not ideal but would it be better to just leave out the Marmox ?
So many questions I know !
Many Thanks
Many Thanks
