Hi.
Can someone please confirm the correct way to insulate a floor before screeding.
The floor screeder has told me to lay the required insulation (80mm) all over the floor before he comes to lay the screed. I mentioned about laying vertical insulation around the perimeter and he told me that there's no need.
On the inside of the external walls, I will be fixing 35mm battens and then 12.5mm plasterboard, should I use 40mm of insulation vertically to where the top of the screed finishes.
I was told before that it stop cold bridging and it also creates an expansion gap for the floor screed.
Cheers.
Cheers.
