For someone to specify joists at 200mm centres would be unusual, unless the joists were very small (in depth)?Thanks for that.
For some reason I had 200mm single joists specified. Builder doubled up at 400mm to allow more access for water and electric
Or the floorboards very thinFor someone to specify joists at 200mm centres would be unusual, unless the joists were very small (in depth)?
Or the spans very long?
Probably hardboard!Or the floorboards very thin
Yikes! Although it wouldn't be the first time it has been suggested...Maybe 12mm laminate straight on to joists!!!
yikes?? just brilliant was it yogi bear and boo boo or top cat [later boss cat ] that said thatYikes! Although it wouldn't be the first time it has been suggested...
