Hi everyone,
I've just put down a coat of Bona natural primer (water based) over my newly sanded floor and have calculated that I have enough Bona Traffic HD for 3 coats (very close, but I'm hoping it takes a tiny bit less with successive coats.) I was originally planning 2 coats and denibing with a 180 grit sanding block between first and second. If I plan to do a third coat, should I denib after 1st and 2nd coat, or just after the second coat. I thought it may be safer to go with light denibing between each coat. Any thoughts?
