Hi I know this subject has come up before but none of the previous I could find seemed to cover my problem.
I have a fairly big extension at the back of my house that is as wide as the house, approx. 3.5m x 5m. The whole floor is sloping towards the back garden but we are ok with that as it is not too bad and we hardly notice it.
The floor is that typical 4" square parquet tile effect and is layed on hardboard.
There was a breeze block wall splitting the extension in two until recently so that one side added to our kitchen and gave us a nice long kitchen and the other bigger half gave us a dining room. Well we knocked down the wall so that we can have a massive kitchen-diner with a big country table in it, but doing this has left a 2m plus trench in the floor where the wall is with the parquet flooring each side. Trouble is although the floor is one when it gets near the back door, at the beginning there is well over 1/2" maybe nearly an inch difference either side of the trench (shallow trench by the way).
Now we are laying a new laminate floor thoughout the ground floor which I have started in the hall and was advised by our builder friend to lay on top of the parquet as it all works out the same height of "under stuff" as the 7mm green felt pads I used in the hall. He has advised that we just lay that 3mm cushioning between the laminate and where we have parquet. He said the parquet gives a good base and it would be crazy to remove the large amount we have so its best to lay on top with the 3mm stuff between.
So now if I use a latex leveller to level the two sides of the trench which sounds fine what am I going to do about the fact the whole extension slopes slightly down towards the back, wont the leveller all start running out of the trench towards the back door?
I could take some of the parquet away on the high side and maybe even some of the hardboard underneath and then level but still what about the whole extension sloping towards the back?
I know I cant really use filler but as a way to explain, if I was using filler I could use a long straight edge and fill the trench level until I was happy but with latex leveller (which I have never yet used) doesn't it just do its own thing and find a level?
Sorry for such a long question, but any help or tips please?
