Floor levelling compound
14 Nov 2005
Aberdeenshire
Hi
I had a concrete floor which was a bit high and uneven (20mm or so rise and fall) laid over water UFH pipes. Long story as to why. The room is 13M by 4
I've ground the floor down by the requisite 20 mil or so, and checked it for level all over. It's still a bit uneven but lower than the required height now.
I've filled the lowest points with self leveller with sharp sand, and I'm wondering how to do the final coat. It's an everbuild water mix compound that I'm using. Will it find its own level perfectly, or can I run a power float over the top to get it properly smooth (There's about a 2 - 3mm coat needed all over, I reckon)
We're going to be laying engineered wood flooring, over a foam underlay but the heating's not gone on yet, although I do have the means to heat the room using fan heaters. Would I be OK to lay the timber into a cold room, then have the heating cone on and be brought up to temp, as slowly as possible. We're looking to fit the kitchen on top of the floor, rather than down onto the concrete itself.
