I need to replace 2 joists downstairs where there's been a problem (I've known about it a while) where the floor plates and joists have been built (1940) too close to the external wall. Due to this the damp has transferred to plate and then onto the joist.
I've ripped up the floor boards and taken out the rotten joists and plates.
Could I ask your advice on fixing the problem?
Do I do the followings:
1. Build up the wall where the plates sits using 1:4 ballast mix
2. Sit a strip of DPM on the wall
3. Sit the plate (2x4 treated) on the sheet of DPM and keep 1 inch away from the wall
4. Sit the joist back on the plate (2x4) treated
5. Lay the new floor boards on top - the problem is that they were 120mm x 22mm deep floorboards - I guess I this I can only find 18mm deep wood. Is this going to be case these days? If so.... what do I do to build it up as I've got lots to slot in.
I might add another joist next to the one I've cut the floorboards from so I have somewhere nice and stable to sit the first part of floor board - what do you think to that idea?
Would I need to fix any of the above wood down btw?
Thanks for your help
