The dinning room floor in our new house is sinking but I have access to underneath via the cellar. Floor is 4m by 4m and supported by 4x2 joists! The problem is that the previous owners decided to replace the sleeper wall running along the middle of the span with a 5x3 timber beam going the entire 4m length, this may have sufficed but a section of the beam was then cut out (presumably to make headroom in cellar) and now the whole floor is sagging.
It will only get worse so I need to fix it, I can either build a new sleeper wall or replace the broken 5x3 beam with new one. I'm not convinced that the original timber 5x3 beam is strong enough and my preference is to replace it with a 4m 5x3 steel beam, does anyone know if this will be ok, a bigger beam would be much harder to fit as 5x3 wil just slot straight in?
