I have had a real single story extension built onto my terraced home. The extension is water tight, the rads have been put in (and removed for the plasterer), the eletrics have been installed except for the final installation of the socket and the lights fittings. The plasterer is currently plastering.
I currently have a floor but only what the footings men put in. After the plasterer is finished the builder needs to put the final floor in (i think this is floor screeding). i am planning on putting a wood floor down (engineered) and the plasterer said i should wait an inch a month for this floor screeding to dry before putting the wood floor down. The builder says 6 to 8 weeks will be enough and i quote "you will know when its dry"
The floor screed (if that is what its called) will be between 2.5 to 3 inches thick (depending on where you measure it). Who is right?????
