good morning troops,
am a resonably experienced builder in the carribean and have been sent to your well recommended group for a bit of advice and help.
i am looking a small , 10 m2 ) very rough concrete slab that i need to tile. it is not acceptable the way it is for all the obvious reasons. some areas are out of level by an inch ( 25mm) or more others by an 1/8 (3mm).
i am looking at pouring a hand mix self leveling screed and have found a couple of , what seems on their face, to be good products. Mapei Novaplan 2 and novaplan easy.
pot life is 60 mins so that gives me time to hand mix in buckets and pour but there is a specification in the data sheet called " flow time" at 10 minutes which i don't understand. is flow time the amount of time it takes this stuff to ultimately seek its own level or is that the amount of time you can move it around before you lose control of it ? as said, it is a small area so i figure no more than a few cubic feet total to address the whole thing starting at the deep spots and moving away but if i only have 10 mins from the first bucket to the last, then thats just not going to work...
any sage advice ?
any sage advice ?
