I already posted on the fact that my circa 1930's house has bouncy floors. on lifting up the floorboards it was found that the inner wall(cavity construction), well the part on which the ground floor joists rest was missing. Not all the wall was missing, about a metre and a half below the window. So these joists are resting on a wooden wall plate with no support below it, thats why the floor is bouncy. The wall has not fallen down (otherwise they would be lying on the sollom,part of the wall has been taken away).
Someone mentioned that the wall has been partly taken away to allow air circulation below the floorboards to prevent dry rot.
I now need to stop the floors from bouncing so i wish to rebuild this wall.
Do you think if i use air bricks built up using the appropiate mortar this will give the support but also prevent dry rot,
regards
scott
regards
scott
