In a shower room at a small campsite on a farm. We've made a sloped concrete floor for the shower which I've put floor tiles onto using waterproof tile adhesive and grout. That appears to have worked absolutely fine. The sloping shower floor is separated from the rest of the cubical by a small two brick high wall. I've used the same adhesive and same tiles to tile the sides and top of this wall, using plastic tile edging strips at each top edge. This is basically a step into the shower. For some reason the adhesive under the tiles on the top surface of this wall hasn't set after nearly 3 weeks. On the sides it's stuck to the point where my fingers can't remove the tiles. The bricks are some left over block paving bricks from another job. The adhesive had set on the cement between the bricks, but not on the top of the bricks themselves.
Any suggestions as to what's going on?
Ant
Ant
