THE BATHROOM FLOOR HAS JUST BEEN LAID AND THE GROUT IS STARTING TO COME OUT ALREADY.THEY ARE LAID ON SECURE PLY BUT I'M CONCERNED THERE IS MOVEMENT WITH THE TILES/PLY/FLOOR BOARDS CAUSING THIS.ANY IDEAS OR IS THERE A DURABLE GROUT AVAILABLE?
You can’t afford to cut corners if there is any chance of movement or flexing, you must use a flexible adhesive & grout. The quality stuff (Bal) is expensive though which is why some will baulk at using it. It could of course be a problem with the floor itself but I would get in touch with whoever did the job & ask them to put it right
