floor tile removal
28 Oct 2007
Buckinghamshire
Hi ive just had a disaster removing grout from the floor tiles ive scratched one. whats the best way to remove it .The floor has been leveld using leveling compound & ply. My neaibour has suggested a propane blow torch.would this work? Thank you
interesting idea using a blow torch, is he a profesional? :LOL:
try this
http://www.extensive.co.uk/product.php/22/0/
Are you asking how to remove grout, the scratch or the tile?
Hi Thanks for your reply I want to remove the tile .But if you know how to remove a deep scratch tell me more . the blow lamp suggestion was to heat it up to till it cracks.
my apologies head wasnt in it this morning, i was thinking you had damaged one and wanted advice on how not to damage anymore.
so your neighbour is telling you to use a blow torch to remove a tile? :LOL: :LOL: :LOL: :LOL: :LOL: :LOL: :eek: :eek: :eek:
remove the grout from around the sides of the offending tile, then using a hammer and chisel smash the bejeebus out of it! then remove all the bits and smooth underneath, all nice and ready for new tile to be put into place.
i assume because the tiles are lying on plywood that they are sitting on a wooded floor, so hitting the tile is a no no as not only will you loosen the offending tile but probably loosen about a dozen surrounding it as well, i normally run the grinder through the tile and make it into more manageable pieces, then using a old chisel or old screw driver lever the offending tile out. using a hammer can make a 5 minute job into a 2/3 hour job.
just because its levelled you assume its on wood? ever heard of a uneven concrete floor?
me neither they are all perfect ;)
welcome to the forum
