hello, can anyone give me advice on ceramic floor tiling spacing. what are the pros and cons of butting the tiles together would it look odd or is it an acceptable practice. cheers
Don't do it. You'll neeed to make sure your floor is dead flat or the slightest irregularity will show by the tile corners kicking up. Also, tiles are not always exactly the same size - butt jointing will show these fact by the gaps between the tiles stepping out.
The only benefit is that you won't grout.
I wouldn't do it if I was asked. You should think twice.
