Floor tiling disaster
21 May 2007
Northamptonshire
I'm halfway through re-tiling my bathroom floor.
I pulled up the floor and the previous owner had used hardboard under the floor tiles. So I just copied that bought new hardboard, cut it all to shape and now have several wobbly tiles.
Having now done my research it seems I should probably have laid 25mm ply as the floor's not that flat.
1. Can I rescue the wobbly tiles?
2. Do I need to just scrap it and start again?
3. I have two tiles that need small sections cut out for the radiator pipe. It doesn't seem worth renting a wet saw to do it and chipping away at them with tile cutters breaks them every time. Any suggestions?
I'm crap at DIY but this website really helps. Thanks in advance.
Possible,if you can lift them out with a chisel or scraper depending on the adhesive used you may be able to soak them and remove it (sometimes works :) )
You will definatley need to take up the hardboard,you will then need to board over with 12mm wbp ply,screw down with 30mm screws so as not to pierce and pipes under the floor every 200mm.
When refixing use a flexi 1 part adhesive you will also need a flexi grout
Im sure one of the guys on here will be along soon to recommend a bal product :LOL:
Depending on the tiles and your patience you could use a tile hand saw but wet saws are much easier and give a better finish ;)
I thought I would have to start again. Which is annoying but I suppose you should do your research first.
Managed to find a 600w tile saw in Homebase this morning so i'll see how that works.
Thanks for your help.
For such a small job that should be fine,I brought a cheap one in feb,10 months,11 bathrooms,2 kitchens plus floors and fireplaces and its still ticking along,(had 2 new blades though :D )
Hope it goes well for you and Merry New year!!
So just to confirm:
I CAN use 12 or 18mm WBP on a concrete floor to tile on? Seems dead simple compared to pouring screed/levelling etc. Would I need to prepare the floore beforehand in some way or install those vapour barrier sheet thingies?
Application:
Plan to stick down some Travertine/granite/marble or porcelain tiles in a kitchen
Warmest Regards
So just to confirm:
Application:
Warmest Regards
if it's concrete use self leveling floor screed quicker than boarding ans sets in no time.
As seco says the best thing would be to screed the floor first when working on a concrete base.Only ply when tiling on a wooden floor.[/quote]
