Just had a 1st floor bedroom insulated to building regs standards. Followed the information the building control officer wanted and Celotex approved method.
25x50 treated battens against solid brick outer wall with 50mm celotex over that and then drywall. It's not the method recommended on the celotex pdf for ga4000 (they show celotex then battens, then PB), but celotex confirmed that they approve this method too.
I had blocks of wood in walls for radiator fixings, but we've decided since to put a smaller radiator in
So I was cutting a new hole to fix wood direct to outside wall, under window, for new rad bracket.
I noticed that on the back of the celotex there was condensation. My fingers got wet from back of celotex, as I was messing about in there, but the wall appeared dry.
The floorboards are all loose atm. 6mm plywood, underlay and carpet will be going on in the next few days.
However, this condensation concerns me.
The celotex on the external walls is taped for VCL plus all drywall has been Gyproc drywall sealed with two coats as an extra VCL. Thus ceiling and walls have VCL, but not the floor.
Thus vapour can get through floor and up behind walls.
Is this a concern?
At no point does anyone ever mention providing a floor VCL.
Is this a concern?
