I need some floor varnish for an oak floor. Toolstation have a special deal on Liberon Natural floor varnish. Is this stuff any good or should I avoid?
Hi there
Libron is an established name with basic to middle of the road product so it probably won't be bad. That said it depends how much you need because at £8.25 for a 0.75 litre tin that actually works out at £55 per 5 litres. Working on 10m2 per litre as a standard consumption rate, and most floors needing 3 coats to provide a workable and durable coat you will need a tin for every 2.5 meters square on your floor.
A good quality product from Bona or Dulux would only set you back the same per 5 litre.
