Hi
I have just installed a freestanding bath into our bathroom. It runs in line with the floorboards which sit perpendicular on the floor joists (as per normal). The floorboards are 1 inch thick and sit on joists that are 2inches by 9inches. The joists is 12 inches apart. The rear claw feet of the bath (under where you sit in the bath) sit on top of each floorboard almost exactly halfway between each joist. The front feet I have positioned so they sit on top of a joist. Unfortunately I cannot position the rear of the bath on top of a joist as there is not enough room. Should (can) I support the floorboards on which the rear 2 feet sit by fixing another 2 joists with joint hangers (perpendicular to) between the two joists so that they give extra support to the floorboards on which the rear feet sit? Or is this unnecessary as the floorboards will take the weight anyway? Thanks all.
