Hi All
First question on forum, so bear with me (I have looked at previous posts for a similar without luck),
I am currently doing-up the first floor of my victorian house and want wooden floors all over. It has previously had carpet etc. The first bedroom has floorboards some of which will need to be replaced, if I am to sand this floor. My question is :
Can I replace the damaged floorboards with brand new? If not, why not? Should victorian reclaimed boards be used instead?
There are some gaps between the boards which I assume I can fill prior to sanding or should I just forget the whole thing and lay a wood floor on top of the boards...
Any advice gratefully received
