I have finished removing 22mm floorboards and replaced with 18mm wbp plywood in order to tile the floor. My local Wickes and Build Center did not have 22mm ply. I added some noggins and screwed the ply every 25mm or so. The whole floor now seems more springy and less sturdy than it did with the floorboards. For example when I stand in the middle of the room and bounce up and down a little a bookshelf at the edge of the room wobbles a little. Any comments/suggestions as to what I should do?
correction: I screwed the ply every 250mm not every 25mm
