Flooring a Loft
13 Nov 2006
Angus
I need to put down some flooring in my loft, is this just a simple case of laying chipboard across the joists ?
i assume we are talking light storage !!
what size are the timbers
at what centres !!
what is the unsupported span underneath
I'm no tradesman, so bear with me:
What size are the timbers - are you meaning the joists that go along the floor/ceiling ?
At what centres - Dont know if its 400mm or 600mm
what is the unsupported span underneath - do you mean the ceilings in the rooms underneath ?
well measure it then!
timbers size is the things that hold the ceiling up
unsupported span is the distance they run between supporting walls.
Also is it a fairly modern house with timbers arranged in a W shape
A photo or two would help a lot
if its general light storage just lay your chipboard down.there is a small allowance built into the truss design for light storage.
