Flooring advice for a complete amateur
16 Jan 2016
I've never done anything with flooring before.
We have old tile-like things under our carpet and I want to lay some sort of flooring on top of this.
It is a downstairs floor, does this mean I don't need a damp proof membrane applied first?
My plan was to just buy some self-levelling compound, like this: http://www.pureadhesion.co.uk/mapei-ultraplan-renovation-screed-25kg.html
Then, I can just buy some stuff and start to lay it... it all sounds very straight forward.. so i must be wrong! All advice appreciated. :)
First of all decide on what flooring you want?
If you are floating wood / laminate over the top the tiles can stay down.
If you are gluing flooring to the base then you will need to take them tiles up before you prime and screed the floor
Sorry for late reply.
I'm going to put down laminate and hope to float it...
The floor is level but some of the tiles have broken up when removing the grippers. What can I repair these with or will it be ok as is?
