Flooring for Lofts
7 Oct 2005
:D Hi - I would like to put flooring down in my loft so it can be used for storage. I have heard you can get boards that lock together but can't source them. Any ideas? If this is not true what should I use instead and where can I get it?
Hope someone can help me ;)
Try here for starters
If no luck, try this one
Thanks for that. I had already done search engins and checked out this site with no joy that is why I am asking for help. Any advice would be great!
I'm sure you mean the chipboard T&G loft boards, available at most sheds.
See here
Use 3"x1" timber flat in the opposite direction of the ceiling joists and position it so that the T&G is on the centre of the 3"x1" for supports. This way will give you a cross air flow underneath and no slots to cut out for pipe/wire etc. You can buy T&G loft pack of 5 but I think it will be cheaper to buy 8'x2' or 6'x2' T&G sheet if you can get it through the loft trap.
